very confused
I put in an application, as I am a student, for Solid Edge for students. I then got the following email:
Dear Student,
By now you should have installed Solid Edge and be up and running? If not, you can get help from the Solid Edge Student Forum.
If you’re ready to start modelling we have some great tutorials to get you going. To access these tutorials; from the Solid Edge Startup window (the window visible when all Solid Edge documents are closed), look for the “New to Solid Edge? Start Here” section. Under ‘Getting Started with Solid Edge’. Use the Part Modeling, Assembly Modeling, Detailed Drawing Production and Simulation links to quickly learn how to model parts, build assemblies, create drawings and test your designs using simulation.
Use the Solid Edge self paced training to get additional step-by-step instruction on a variety of modelling topics.
If you have internet access, and you’ve completed the Getting Started training and tutorials, there are many additional self-paced training courses available; access them now.
You can also “LIKE” our Solid Edge Facebook page. You can see examples of products designed in Solid Edge, chat with experts and post your own designs to our page. Make sure to check back often for future design contests!
Design better,
Mike Brown
Director, Solid Edge Academic Relations
I've been given no codes and any links to download though. This is the only email received.
Please help.
Re: very confused
Hi there,
A little unusual, but, all I can suggest, is try signing up again to invoke a new email.  [hopefully with link & code]
EDIT: the portion for the download link you'll be looking for is indicated in this image.....
