viewing tool icon size
Does anyone know if you can change the size of the view manipulation icons at the bottom of the screen (alongside the Find a Command text box)?
Re: viewing tool icon size
Yes.  In the Windows Display settings, change the scaling factor to something larger.  Be aware this scales everything in all apps, not just Solid Edge.
http://Grundey.blogspot.com
Thanks Ken.
