welding in a prt file?
Good morning All,
In ST8 we are able to weld within a part file. it looks like this only works with prt file and not sheet metal, please correct me if i am wrong. I would like to know why would this be better or referred over just welding within a weldment asm file? How would this be used? All opinions are welcomed.
Nathan
Nathan M. Gardner
https://www.etsy.com/people/NathanMGardner
Be sure to check out my work!!
Made in Maine Wood Carvings
Re: welding in a prt file?
When in sheet metal switch to part and put in the welding ?
I haven't got ST8, so I this is just a guess.
HP Z420 16GB RAM
Quadro K4000
ST10 MP3 on Windows 10 Pro 64.
So it would seem you can add weld to a sheet metal part if you go into the prt environment.
Nathan M. Gardner
There are several reasons for adding the capability of creating weld beads within a part file:
  • Previous to ST8 we created weld beads as assembly features which caused the assembly to be heavy.
  • When a weld bead is defined in part, the Draft environment will recognize them as weld beads and be able to extract the mass properties for them.
  • Full display control of weld beads.
  • Full control of material properties.
  • Gives you the capability to use "Duplicate Component" to put weld beads on similar components quickly.
