weldments in ST10
We are looking into moving to ST10 from ST8 shortly. I wanted to know if anyone knows if there's any inprovments to measuring the amount of weld in each weldment?
Nathan M. Gardner
https://www.etsy.com/people/NathanMGardner
Be sure to check out my work!!
Made in Maine Wood Carvings
3 REPLIES 3
Re: weldments in ST10
One thing to note is that weld commands are also now in Part (ST10).  This might be helpful for weight calculations, BOM info, etc.  Because they can be their own part(s), you can also utilize the new Clone Component to easily replicate welds via geometry recognition.  You can still work with weld information within the assembly also, but the new options for Part have some cool benefits.
Kevin Grayson
Solid Edge Technical Consultant
kevin.grayson@siemens.com
I can't wait to try it!
Nathan M. Gardner
Hi @ngardner
HI @grayson
for Your info, weldment in parts is there from ST8 on.
So You still can use it with ST8 too!
Wolfgang
