what is the hardware requirement for solidedge ST5?
ST5 Requirements
ST5 Requirements
Terry Tyson
Software Automation Designer
Re: what is the hardware requirement for solidedge ST5?
Esteemed Contributor
The type of work [part models / structural analysis / assemblies / drawings...etc] you want to do in Solid Edge will have a direct affect...keep in mind, the system requirements typically listed, are a low end base line and rocket skyward from there, dependant on those needs.
If you could shed a little light on the type of work you're likely to do,...it'll be easier to offer a suggest appropriate hardware to match.
