what is the use of over lapping command in part & assembly model.?
dear sir,
         what is the use of over lapping command in part & assembly model. how to use this commend . if you have any youtube video link please sent to me. Its use full for me .
Thanks & Regards
    ANAND.G        T
Re: what is the use of over lapping command in part & assembly model.?
Dear Anand,
This select option does what it says. If you only want to select that which is fully enclosed by the box then do no t select the icon. If, however, you want to select things which are fully enclosed in the box as well as those things which the box touches then select the icon. You might think of this option as being "I want to select everything which is connected or local to the thing I am selecting."
This video might make it clearer.
This video is currently being processed. Please try again in a few minutes.
(view in My Videos)
Also remember that the results of your selection will be view dependant. If you alter te view angle then other things may or may not be in the selection zone.
Cheers
Mark
