whats means in assembly environment, a padlock icon next to a piece inserted?
hi,
please, look at the attached image.
I'm using ST6. Why do I see a padlock when I insert a new part in an assembly?
Thank you in advance.
Re: whats means in assembly environment, a padlock icon next to a piece inserted?
It means the status of the Part is "Available". The Status -> Display Status command on the PathFinder shortcut menu turns on and off the display of symbols adjacent to the document names in PathFinder.
Please see the following Solid Edge Help documentation for more on the symbols in the PathFinder:
http://docs.plm.automation.siemens.com/tdoc/se/109/se_help/#uidSmiley Tonguethfnd1a
Thank you!
