when opening solid i get this msg
Not applicable
when i click solid edge icon i get this msg
system clock has been setback
tried many times to reinstall but every time a get the same msg
pls help
Re: when opening solid i get this msg
Not applicable
Well is you System Clock set correctly to today's Date?
> pls help
Not applicable
It sounds like you may need to set the time & date correctly
in your BIOS (press Del or F2 etc. on boot-up depending on
brand).
Rick.
"ibrahimsaleh2009@gmail.com"
wrote in message
news:ibrahimsaleh2009gmail.com.5bdwob@noreply.bbs.industrysoftware.automation.siemens.com...
> pls help
> ibrahimsaleh2009@gmail.com's Profile:
> http://bbs.industrysoftware.automation.siemens.com/vbulletin/member.php?userid=422819
> View this thread:
> http://bbs.industrysoftware.automation.siemens.com/vbulletin/showthread.php?t=48905
This usually means there is a file on the PC with a future date/time which tells the licensing you set the system clock back. You need to find this file/s and remove them before it will work.
Production: ST10 MP7
Testing: SE 2019
http://Grundey.blogspot.com
