xy coordinates in balloon
Not applicable
Hi all
Ballon properties text = xy coordinates.
how?
Lars
Re: xy coordinates in balloon
Not applicable
Lars,
I am guessing that you want to display multiple lines of text with values.
Use a Callout instead of a balloon. you can enter as many lines of text as
you need.
Rick B.
Not applicable
Hi Rick
This is what i like to do
http://peecee.dk/upload/view/248010
can this be automated,select ballon or callout, select point
xycoordinates in ballon or callout line.
Lars
Not applicable
Lars,
If all you are needing is to display the coordinate values at specific key
points,
I suggest you use coordinate dimensions.
It will not put both the X and Y values in the same object,
but will give all X and/or Y coordinates relative to a common origin.
Rick B.
