Adding a part to an existing assembly drawing; connected balloon
Question
Can you add a part to an existing assembly drawing with parts list and have the balloon for the new part connected to the parts list?
Answer
Yes:
  • Go to Solid Edge Options in Assembly file, then the Item Numbers tab and check Maintain Item Numbers, w/Atomic-top down options selected.
  • Next go to the Parts List Properties in Draft file, Options tab and check Use Assembly Generate Item Numbers
  • Next go to the List Control tab in Parts List Properties and select Atomic list all parts option and click OK
  • Update the Parts List and the Reports and Parts List should match item numbers and order
Contributors
