Advanced Piping and Tubing
This presentation will introduce you to Solid Edge’s XpresRoute route environment for piping and tubing design. See how easy it is to design and create these routing features in your assembly connecting components together with pipes and tubes. We will also look at how to take advantage of Solid Edge’s Standard Parts database to quickly and automatically place the correct fittings in your piping design. This presentation is geared towards users whose product design includes pipe and tube routes.
