Animating Assemblies
Learn about the new ST8 methods that are available to animate (or simulate) component movement in assemblies. We’ll look at how to manipulate springs and create chains and other assembly types in preparation for animation/digital prototyping. Part of this session will use the new variable table motor, which can be used to change variable values to simulate complex component movement.
