Catia V5 translator
Siemens Theorist Siemens Theorist
Siemens Theorist
Question
What versions of Catia V5 files  are supported by Solid Edge
Answer
Solid Edge ST 5 CATIA V5 Translator supports  R8 – R21 SP1.  ST 6 will support up to R22 SP4 . Starting with R22, DS has changed their release terminology. R22 is called V5 – 6R2012 since these releases are being marketed as a bridge between V5 and V6.  The latest release from DS is V5-6R2013. Solid Edge cannot read/import V5-6R2013 (R23) at this time.
