Changing Draft Angle Direction
Question
How do you change the direction of the Draft Angle when adding draft in Synchronous mode?
Answer
After selecting a face to draft, a ball with two arrows pointing out of it in opposite directions will be displayed. Click on this symbol to reverse the draft direction.
