Changing Tubes and Pipes Length
Question
How can you get a total length for Tubes and Pipes?
Answer
In the XpresRoute environment, on the Tools tab there are two commands that will extract this information. Bend Table will generate a report for tubing, showing the bend information and total tube length. Pipe Reports will show total lengths and diameters for individual or all pipes, with fitting information (optional).
Contributors
