Changing the distance between stacked dimensions
Question
How do you change the distance between stacked dimensions?
Answer
In the Styles dialog select the Dimension Style and Modify. On the Lines and Coordinates tab locate the Stack Pitch in the Dimension Lines section. The default value is 3 x font size. Change it to suit your needs.
Contributors
