Changing the font size in a Parts List
Question
How do you change the font size in a Parts List?
Answer
The Parts List uses a Table Style that references a Text Style. To change the font size in a Parts List you must go to Styles and select the Table Style being used and Modify it. On the Text tab you can select the Normal Text Style and Modify it or create a New Text Style with the required font size.
Comments
You say to go to "Styles" to make these edits, where is "Styles"? I don't see it anywhere(currently running ST5)
Steve
Contributors
