Converting a Solid Body to Sheet Metal
MLombard
Retired
Have you ever had a native Solid Edge or imported solid model that looks like a sheet metal part, but won’t convert to a sheet metal part? It can happen. In this session we’ll share examples of how to make these cases work! We’ll also combine a synchronous technology and ordered modeling approach, known as hybrid, to get the optimum and most efficient results. Also, as promised from my session last year, I’ll demonstrate how to implement Multi-Body functionality into your conceptual sheet metal and part design approaches. Multi-Body modeling provides the ability to design multiple part bodies in the same file and publish them later as individual part files and assemblies if desired.
Contributors
