Copy & paste a drawing view to 2D Model sheet
How do you copy and paste a drawing view to the 2D Model sheet
We do not allow pasting or placing of drawing views of 3D models on the 2D Model sheet. You can, however, right mouse click on a drawing view on the working sheet and select Draw in View. Then you can Ctrl-A to select the geometry and Ctrl-C to copy. Close out of the drawing view and go to the 2D Model sheet and paste. This will paste the actual geometry from the view.
