Creat Weldment
Question
How do I create a weldment in Solid Edge?
Answer
Weldments are created in the Solid Edge Assembly environemnt.
  • Open an existing asm and goto to the tools tab on the command ribbon.
  • Select the weldment command.
  • Check the box in the dialog to mark/toggle the asm document to a weldment asm.
  • This will enable the weld commands on the Features tab.
Contributors
