Create Drawings in Draft
Question
How do I create drawings in Drafting from my 3D models?
Answer
There are a few ways you can create drawings from of your 3D model.
  • First, you can create a new drawing with views directly from the model.
  • With your 3D model open click on the application button at the upper left.
  • Move the cursor down to to New without clicking.
  • Move over and down and click on Create Drawing.
  • Click on OK in the dialog.
  • When the drawing is displayed simply click to place the drawing view.
If you are alredy in a new drawing, run the Drawing View Wizard command on the Home tab and in the Drawing Views command group. In the dialog you will select the model from which to create drawing views.
Contributors
