Create Simulation Study
Question
How can a create a simulation study of a sheet metal part?
Answer
  • In the sheetmetal file, creae a midsurface of the sheetmetal part.
  • Then create a new study and change the mesh type to Surface.
  • Select the midsurface.
    When meshing it will use 2d shell elements on the midsurface.
