Create Text
Question
How do I create text in a sketch?
Answer
  • In Sketch mode, click the Tools tab on the ribbon.
  • Next, click the upper case "T" icon in the Insert group.
  • This opens the Text dialog where you can set your font, language, size and several other useful things.
  • Enter what you want your text to say, press OK and then place the text.
Comments
Hello.  This doesnt work for me in 7.5.  There is no T icon.  I would simply like to add text to a part of the model I'm making, then extrude it in order for the subsequent production drawing to show an engraved feature (in this case, numbers).
Esteemed Contributor
This is a Solid Edge KB.  I'm assuming you are looking for NX info and therefore are in the wrong area...
Contributors
