Create Tube Along XYZ
Question
How do I create a tube path that goes along the xyz directions?
Answer
In XpresRoute you can create pipes with flanges.  When you create the path, you can use the triad to lock to the xyz axes.  As well, you can also lock to the xy,xz, and yz planes instead of the axes.
Contributors
