Creating a synchronous thin-wall with a unique thickness
Question
How can you create a synchronous thin-wall with a unique thickness?
Answer
When a thin-wall feature is created all faces have the same thickness. To change the thickness for any individual face, select the face you want to change and select the thin-wall handle. You will have a button for “selected faces only”. Select this button and change the value, which will only be applied to the selected face.
