Define Default Line Weight
Question
Can I define a default line weight for visible lines in my draft template?
Answer
Yes. Open your draft template and go to View > Styles > Line > Visible > Modify > General > select new "Width" > OK > Apply. All views placed will inherit this lighter line weight.
Contributors
