Define Text Control
Question
How to define the Text Control option for text boxes during placement?
Answer
When creating text boxes in ST5, depending on how you click on the window to place them, you will get two different Text Control options.
  • If you do a single click on the window so that the cursor shows and you start typing, you will get the Fit to Content option active.
  • If you click and drag to create a small text box rectangle, you will get the Fixed - Wrap Text option active.
So if you know which option you want, either just click or click and drag to get the option you are looking for.
Contributors
