Deleting Parallel Relationships
Question
How do I delete a parallel relationship applied between two lines in a Synchronous sketch?
Answer
By default, we do not show sketch relationship handles in Synchronous. Go to the Relate section of the Home tab and toggle Relationship Handles. Then you will be able to select and delete any relationships applied to your sketches.
