Draft does not stay connected together
When I draw simple geometry in Draft it does not stay connected together. For example I draw two endpoint connected lines.
I click one of the lines and   drag it's location. The other line does not stay connected. Why is this?
Maintain Relationships needs to be enabled. On the Sketching tab and in the Relate
command group there are a couple of buttons that need to be pressed to enable   relationships (constraints)
such as end point connect. These are the Maintain   Relationships and Relationship Handles buttons. Enable these
by clicking them   down and then draw your geometry.
