Drawing View Creation (Under the Hood) Part 2
MLombard
Retired
Like tuning a high-performance engine, you can use many tools that drive drawing view creation to set up Solid Edge for the performance and workflows that best suit your needs. This is a 2 part series that will cover the many Solid Edge options that are available to control drawing view creation and display. Also covered will be the Drawing View Wizard and how to save and reuse settings to optimize the drawing views of the different model types that you work with every day. Part 2 will cover topics related to what Solid Edge Options map to Drawing View Properties, setting up edge display defaults and using saved settings with the drawing view wizard.
Contributors
