Dual Dimensions for Callout
Question
How do I format a callout to show dual dimensions?
Answer
Use the format %{%BS/du} . In Help, go to the Search tab. In the box 'Type in the word(s) to search for', type ‘callout dual unit’ (no quotes) Click on the 'Format codes to modify property text output'. There you will find the code /du is for dual units.
Comments
PLM World Member Pioneer PLM World Member Pioneer
Any advise on how to get this to work with hole callout %HC - %{%HC/du}? Doesn't seem to work on %HC with ST4.
Contributors
