Editing a Frame
Question
How do you edit a Frame?
Answer
To edit a frame select the frame component and click the edit command that appears on the screen. (Little Icon) The edit UI will appear. Select the step you want to change (Path for example) and modify the input. Click finish to complete the operation.
Contributors
