Electrical Design: A Hands-On Experience
Mark Thompson, Solid Edge Field Support, Siemens PLM Software
Level: Basic
Solid Edge offers a harness design environment with advanced tools to design wires and cables.  In this hands-on session you will use these tools to build a harness within a custom car dash.  First you will experience the manual method of wire creation and then using the Harness Wizard, you will experience an automated way to read the wire definitions in from an ECAD system.  You will finish the design by creating a flattened nailboard view of the harness.
