FEA in Solid Edge and FEMAP
MLombard
Retired
Come learn how to apply finite element analysis techniques to your models using Solid Edge’s built-in simulation as well as Femap, our CAD-independent, advanced simulation program.  Digital simulation allows you to predict and improve the performance and reliability of your models, reduce time-consuming and costly physical prototyping, evaluate different designs and materials, and optimize your designs.  This session will show you the benefit of integrating simulation in your design work, with emphasis on interpreting the results of an analysis to effectively influence product design.
