‘File’ options with the Redefine Links command
Question
How do I use the ‘File’ options with the Redefine Links command?
Answer
When using this option, you need to use a text file whose content is a list of documents for which you want the links fixed. You will be prompted for the current link path (bad) to the 'Redefine link to' (good one).
Contributors
