Focus On Weldment Design
Find out how the new ST8 weldment workflow has been expanded to enable re-use of weld features/beads in multiple assemblies for increased productivity. Performance is also increased due to the ability to pattern the beads as components using standard assembly patterning operations.
Contributors
