Frame Design in Solid Edge
Learn about creating frames, defining the origin and orientation of cross sections, applying various end conditions, extending and trimming to other frames and components in assembly, fetching cut length, and applying uniqueness criteria in parts list and beam simulation.
Comments
Hi.
I am using frame design which is good.
I am having issues with end treatments.  The instuctions and online help doesn't seem to be user friendly.
Please see below what I am trying to trim to frame.  I have tried everything and nothing seems to work.
Any detailed help would be great.
Hi.
I think I have got it figured out.
I managed to do the trim, but only when I closed the main assembly and draft.
Is this what I should have done?
