Getting The Most Out of Solid Edge Help and Training
Kevin Riggs, Learning Media Development Manager, Siemens PLM Software
Level: Basic
This session describes the information in Solid Edge Help and Training and how it supports your work.  Whether you are new to Solid Edge or have used it for many years, you will learn where to find the information you need to increase your skill.  The information available to help you use Solid Edge more effectively has grown immensely to support the growing power of the software itself; this session will show you how to find just the information you need, perhaps more quickly than you have ever been able to find it before.
Comments
Dreamer
Dreamer
Where can I find very basic training in english.  Im in kindergarden level!  Smiley Sad
@SpicZayas70 try starting here:
http://docs.plm.automation.siemens.com/tdoc/se/2019/se_help#uid:xid1129778:xid1046153:index_xid61839...
If that is too simple or not quite what you are looking for you can walk back up the Training breadcrumbs and find more material here:
