Hands-on: How to Use Assembly Occurrence Properties
MLombard
Retired
In hands-on this session, we’ll show you how to create Custom Occurrence Properties, new ST9 functionality that allows you to assign unique metadata to parts or subassemblies every time that part or subassembly is used in the assembly.  We will take a look at how to create and control the behavior of these custom occurrence properties as well as how to extract the property information on a draft sheet.
