Keeping only the outside of an assembly
Question
How can only the outside of the assembly be kept instead of all the parts inside the assembly?
Answer
One simple way to accomplish this is to export the assembly as a Parasolid file, and then re-import the Parasolid as a part file before providing it to a supplier or customer.
