Making more than one flat pattern generated in a single file
Question
Can there be more than one flat pattern generated in a single file containing more than one Sheet metal body?
Answer
No. If a file where Multi-Body has been used and generates more than one sheet metal body in that file, you can only have “one” flat pattern per file, not per body in that file. Consider “publishing” the bodies to their own files if each requires a flat pattern.
Contributors
