Meaning of "View Relative Delta Z"
Question
What is the meaning of 'View Relative Delta Z' for Measure Distance command?
Answer
The measure command adds a purple triad right after the second point is selected. The user can compare the axis of the purple triad with the axis at the origin (red, green, blue) that gives a better understanding of the delta z in the Measure Distance dialog.
Contributors
