Merging cells in a User-defined Table
Question
Can you merge cells in a User-defined Table?
Answer
In the table properties select the Data tab. Right-click on the column that has the cells you want to merge and select Format Column. At the bottom is a checkbox for “Merge vertical cells with the same value”.
Contributors
