Migrating SolidWorks Files to Solid Edge
MLombard
Retired
Learn how to migrate SolidWorks parts, assemblies, and drawings to Solid Edge.  This presentation will include live demonstrations, showing the migration of the various SolidWorks constructs. This session is ideal for users that have archives of SolidWorks data and want to reuse that data in Solid Edge.
Comments
 Hello!
Did yoy verify the feature "Associative drawing files" between .par and .dft after migrating from Solid Works? I use Solid Edge ST version 109.00.03.005x64 and Solid Works 2013. Files from this utility was received but without associative link.
Now all it's OK. Thanks to GTAC's specialist - Reiner Waschkowitz. I needed to install English Solid Edge, not Russian.
Dreamer
Dreamer
Our company has the same problem. Only several computers can migrate SW files with saving link between par and dft and these comps has russian localization. But most of comp can't make migration. What  problem is?
At the first you need to install this utility (Solid Edge Data Migration Tools), and then you should to delete it. After this you will have the needed components. The main intallation packet of Solid Edge has this utility too. Don't forget to delete Temp folders.
Contributors
