Mirror Components Show Different Mass Properties
Question
What can I do if a mirror component shows different mass properties?
Answer
Setting the accuracy to 1 is the best approach if you have a different mass. This has been observed on very thin mirrored components. Since the computation is not exact, you may still see slight differences.
Contributors
