Models Not Showing in QuickSheet
Question
Why don’t models show up when using QuickSheet?
Answer
Views still need to be populated:
  1. On the Library tab or in Windows Explorer, navigate to the model file that you want to use.
  2. Drag the model file onto the QuickSheet template.
  3. The template populates with the model you selected.
Contributors
