Move PMI Dimension
Question
How do I move a PMI dimension value in part if the arrows are too close to the value?
Answer
One way is by zooming into the dimension, so that you can pick the dimension leader and drag the value. The other is to right mouse click on the dimension. The dimension and the leaders highlight. Now you can drag the dimension value.”
Contributors
