Multiple Colors in Draft
Question
Can assembly sketch be placed in Draft with multiple colors applied to sketch
elements?
Answer
Since we can turn on sketches in Draft, you can copy & paste the sketch from the Assembly into 2D Model View, which captured colors and full scale. Then place as a DV onto the drawing sheet and adjust the scale accordingly, element colors were captured.
Contributors
