Multiple Documents Drawing View
Question
How do I change the value of ‘Drawing View’ occurrence property value for multiple documents?
Answer
Change the occurrence property of one document from 'Yes' to 'No', RMB on it and select 'Copy'. Select the other documents while holding the CTRL key and then select 'Paste'.
Contributors
