Opening an STL file in ST3
Question
Why can’t I open an STL file in ST3?
Answer
If you get the message ‘No translator available’, this can be resolved by setting 'Solid Edge Options->Helpers->Start Part and Sheet Metal documents using this environment->Ordered'.
